Slight bit of transformer help
awc
Indiana
Hello all, i need some help.....i have to admit it's been a while since i've tackled one quite like this............here is what i got.
240V 3 Wire Delta System and we need to get 240V with a neutral. Soooooo i want to make sure i'm thinking straight:?
Need 240V Single Phase Delta Isolation transformer (1:1) to 240V Single Phase Wye.
Am on the right track.....it's been a while and my gut tells me just ask for a few extra opinions................if you have any to give:)
Thanks in advance fellas!
Delta and Wye are 3-phase winding configurations. You will need a standard 1-phase dual wound 480/240 x 240/120v xfmr, wired for 240 x 240/120v. Keep in mind phase balancing.
Thank you! See photo. My guy showed up with this. Decided to pick up a transformer from reclaim supply house but this not what I need correct? This will merely stepdown asIMG-20111005-00160.jpgIMG-20111005-00160.jpg it is single phase......sorry but the bolts holding down brain are ruuuuusty. Lol
Let me apologize.....I am attemptimg to do this from phone and it is not going so well. Sorry for errors
Your post indicated you need 1-phase. If it is 3-phase 240v Y you need, no deal. 240v is normally wound as a delta. 240v Y doesn't exist. A mid tapped 240v would get you 120v on A and C phase with a high leg on B. It all depends on what your loads are. More info is needed.
ok, sorry...i guess it's to late for my brain as it's been a long day....
No, i need 240v single phase but with a neutral.
I have 240v 3 phase 3 wire delta and i need to achieve 240v single with neutral.
Sorry but i was completely turned around earlier with the mention of 3 phase.
But the transformer he brought will not work.......now, i may VERY well be completely off here but this transformer will not give me what i'm attempting to achieve, will it?
Loads are lighting and couple of 120V receps for vacuum, radio, misc. Main focus is lighting and they may eventually place an office up there. This will need to feed a 100amp panel. I'm sorry but honestly i think i have myself so turned around on this and if i would take a deep breathe and focus here.............I do apologize for being all over the place BUT i sincerely appreciate your input!
If you need single phase then that transformer will work for you.
240 volt on the primary and 240/120 on the secondary.
Don't forget to ground the neutral.
There are many design issues to determine, not intended for this forum. Don't attempt install unless they are answered.
As GearMan states there are many things to consider, but based on your nameplate you can take any two phases of your 240 delta supply and obtain a 240/120 single phase output with that transformer.
Thank all of you for your input! We'll take a fresh look at this morning and see what we have going on for sure.
Thank you! See photo. My guy showed up with this. Decided to pick up a transformer from reclaim supply house but this not what I need correct? This will merely stepdown asView attachment 5833View attachment 5833 it is single phase......sorry but the bolts holding down brain are ruuuuusty. Lol
I am a student, as I remember a stepdown transformer can be use to step up too, if you reverse the wiring, ? but not too sure, my 2cent and hope some one can answer and help me be more clear on this.
looking for 240vac with a nutural
Don't know if this really has much to do with the original post, but the only time I saw anything close to this 240-vac y connected was at the las vegas convention center 380 vac delta primary and a 219 wye secondary. I think it was Europeon
