Mgarf33
- Virginia Beach, Va
I have 4 LEDs on a single pole configured cl dimmer.
2- Feit 9.9W GU24 bulbs
2- Commercial Electric 10.5W retrofit recessed trim
1- Leviton decor a LED/CFL 150W dimmer control single pole or 3-way
My question is, can the kickstart selector be used for LEDs?
The instructions indicate CFLs only. However, if the dimmer is energized while at a reduced setting, they will take several seconds to illuminate.
When the CFL mode is selected, the startup time is normal =/< 1 sec.
Do I just need a better switch, or should I just use a standard dimmer since they're LEDs not CFLs.
