OK, new to the forum, and I am not an electrician... I am an HVAC contractor looking for some information.
I have configured a battery backup that allows a circulator pump on a closed loop wood boiler system to be turned on via a small inverter when the power goes out (to prevent steam production), but also allows full control of the circulator by the boiler controls when the power is on. It's basically just some relays and an inverter... pretty simple. The inverter is grounded to the rest of the system, and both the line and neutral of the inverter are switched at a relay and fused since it's a Modified Sine wave inverter where the line and neutral are both hot.
Question: The inverter is not UL listed. It's one of those portable inverters for use in vehicles. Will this pose problems with local inspectors and insurance companies?
I don't need a $1000 inverter to run a small pump that only draws .7 amps... nor would that be practical or marketable. My guess it, I do need a Listed inverter. Does anyone know where one of these could be located?
thanks
Nacirema
thanks
Nacirema
