One of the problems with using steam is that you need a high pressure and temperature differential to efficiently get much power out; part of that differential is using a condenser which develops a good vacuum on the exhaust side of the turbine/engine (...cooling water for the condenser... more pumps....place to dump the heat....).
Another problem is that high pressure boilers (over 15psi) do have all kinds of inspection and maintenance rules, need a National Board certificate, etc.
An automatic HP boiler might not need a licensed stationary engineer on duty all the time, but it usually needs one supervising the operation. And it'll usually need a trained fireman on duty which actually firing.
Did I mention controls and maintenance
I'm going to guess the mint farmer is using LP boilers since they're not for power.
