J jbolen Senior Member Dec 27, 2008 #1 Is there an article in the NEC that states that smoke dictators have to be connected to each other.
Pierre C Belarge Senior Member Location Westchester County, New York Dec 27, 2008 #2 That is the building code. The NEC is concerned with the wiring methods.
480sparky Senior Member Location Iowegia Dec 27, 2008 #3 The NEC does, however, have a say in the wiring of those smokes.
B bphgravity Senior Member Location Florida Dec 27, 2008 #4 There are 3 references likely in force by your local AHJ: 1. The building code (R313 of the IRC) 2. The NFPA 72 (Fire Alarm Code) 3. The manufacturer's installation instructions (NEC 110.3(B).)
B benaround Senior Member Location Arizona Dec 27, 2008 #5 jbolen said: Is there an article in the NEC that states that smoke dictators have to be connected to each other. Click to expand... That may be a Cuban Code.
peter d Senior Member Location New England Dec 28, 2008 #6 jbolen said: Is there an article in the NEC that states that smoke dictators have to be connected to each other. Click to expand... No, but I think you would be hard pressed to find a code that allows them NOT to be interconnected. Interconnection has been around for quite some time now...the only place I ever see a stand alone hard wired smoke detector is in apartments.
S sparkchaser1961 Member Location New York State Dec 28, 2008 #7 benaround said: That may be a Cuban Code. Click to expand... Thats hilarious. lol
K kkwong Senior Member Location Sac, CA (I think) Dec 29, 2008 #8 Depending on your location, the Fire Code will have it stipulated as well.
