I was wondering what would be the best idea.
We were asked to add shutdowns via the FACP to smoke dampers to be installed. I get there and the Tin Knockers are about to slam them in the very tight drop ceiling, plenum space. They are 24 VAC 16 VA each, two of them. Spaced 150 feet apart. No one planned on the power for the dampers.
Now I have to power them as well, becuase everyone thought they are powered off the FACP. I don't believe there is a UL fire 24 VAC power supply available. This is a Healthcare facilty and HVAC is on the EM gen set. So, we need to keep the dampers powered in the event of a power loss to keep them open, obviously.
So my thought is find the closest EM circuit and put in a open frame 120>24 transformer close to the dampers and run the power through addressable relays to open on alarm.
My question:
Is it permissible to install an open frame xmfr above a drop ceiling in a plenum space in an HCF (what if its in an enclosure)?
Would adding said xmfr it to a HCF EM light circuit be permissible?(the current draw would be minimal)
I don't deal a lot with HCF power and lighting so I wanted to ask.
This is the first idea I came up with, and everyone is open to suggestions.
My question:
