In an old duplex with a smoke detector on different panels on either side of the common wall, would it be practical to run an 3 wire cable with the black and white capped together and taped "do not use" and the red wire labeled "from the other suite" of common wall, and connecting red wires of all smoke detectors together with the same model of smoke alarm to signal with the low voltage signal circuit safely? If the extra wire is marked low voltage, there should be no shock hazard from the other wires, or perhaps I should just cut the black and white wires off the common cable? It is an 1943 duplex with only one story, and only 600sq feet a side with a crawl space, so no fire sprinklers or exterior bell are required that I know of.
