A/A Fuel GTX
- WI & AZ
- Electrician
Are BRK/First Alert detectors compatible with Kidde/Firex? I know the manufacturers will say no but I see them co-mingled in the field all the time.
			If you push the test button and they work why would they not work in a fire?I would say that, even if the "co-mingled" SDs work when tested, they may not work in a fire
If I need to add a smoke or two (say, for a basement finish), I just figure on replacing all the smokes in the house. They're probably due for it anyway.
I guess I'll just wait for a BRK/First Alert/Kidde/Firex merger and that should eliminate is issue.
Probably not. Kidde already bought Firex and I'm told they are still not compatible.
Polar bear in a blizzard. I've seen it before.Look here.
