Re: smoking router
Could I throw a small spanner in the works here? Most routers have AC adapters, so was it the adapter or the router that let all the electronic steam out? Was the power to the adapter reversed, or was the power from the adapter in to the router reversed (in which case the router was forced to work backwards, and they usually object, violently, as you experienced)?
If powered directly (i.e. mains in to rear of router) then I agree, there may be some protection within the router not designed for full line voltage across the N-E connection - but you may have just had a bad component fail prematurely too.
M.
p.s. can you take a picture and post it? That way we can see what let go?
[ January 05, 2005, 12:21 PM: Message edited by: marcspages ]
