Fulthrotl
~Autocorrect is My Worst Enema.~
- E
Yes, I'm thinking pvc as the stub up. So you think Sch 80 in lieu of Sch40? This makes more since. And, the finishers will have to work around the stub ups like they have been doing for years. Trying to convince some that ENT was not sent from heaven is a problem. Once a supplier says you can save 40% labor costs, most stop listening and start buying.
My issue here is, you can't penetrate the deck. I don't like wondering if I can pull wire later in this stuff.
Are you saying the Red dot 90 is a disaster? It sure looks like it...
Thanks for the info...
Gary
yes. sch 80 is equal to GRC in most situations. and the finishing machine can't break it off as easily.
where i have a lot of pipes coming up, i'll take a 120 volt lincoln wire feed up on the deck, and
weld unistrut to the rebar to turn up for panels. a horrible waste of money? so is losing pipes.
i don't lose pipes in the slab, and my stuff coming up looks good.
the red dot 90 is your worst nightmare to get thru. usually, you've gone 140' and turned down.
then someone hangs flex on it, and goes to a box. the seasons will change trying to get stuff thru it.
carlon used to make what looked like a pvc floor flange, with a pipe thread in the bottom
and a glue fitting on top. glue the smurf right into the socket, and blow string thru it.
pull 5' out, coil it, stuff it into the smurf with a tail hanging out, screw in a pipe plug,
keeping the string hanging out so it can't get pulled back....
now, screw it down to the deck with 4 drywall screws.
if they don't exist anymore, here is how to get there.......
GRC pipe plug. drill two 3/16" holes in the center. use a good pipe plug, not cheapies.
screw it down with two drywall screws to the deck, socket side down.
spin a smurf FA adapter onto the screwed down pipe plug hand snug.
blow string into the smurf, coil up the 5' and stuff it up the smurf, leaving a tail out.
snap it into the smurf FA, leaving the tail hang out.
put a turn of tape around it to prevent seepage.
after the forms are stripped, chuck both screws in a battery drill, and use that to spin
out the plug.
reach up with a hooked wire, and pull the coil of string out.
spin another MA smurf connector into the embedded FA.
run smurf down to the box.
pull wire.
you're welcome.
ps~
smurf is stupid fast. my best day ever was on the 4th floor of the huntington beach hilton.
i did 1,000' per hour for 13 hours. 13,000'. it was 1990, and i was 45. not likely to repeat
that again. ever.
