fishin' electrician
- Connecticut
Would/could this be red flagged?
yes if you cut the seal and pull the meter.Would/could this be red flagged?
All that aside, Yes, the meter is a service disconnect.
yes if you cut the seal and pull the meter.![]()
What is the purpose of the question? A disconnect doesn't have to be located next to the meter unless there is a local ordinance.
A meter is a disconnect. You pull the meter and you have no power.
You open a SP switch to a light fixture you have no power.
You open a disconnect to a motor you have no power to the motor.
Pulling a meter is the same as turning off a breaker. Pulling a meter
is opening the supply circuit. I'd rather throw a switch than remove fuses
to open a circuit but either way, it is a means of diconnecting a circuit.
Thus a disconnect.
So is a pair of klines but not a very safe way.
I don't get it. A meter is not a disconnect. Suppose that was a ct cabinet with a separate meter. That would not disconnect the house.
Theoretically I could have a meter on a pole and the power enter the building and install a disco as near as possible to where the service enters the building. The fire department would not even know where the breaker box or meter might be.
