So went to a friends house...
Whomever did some things right:
1] The loop on the screws is properly counter-clockwise.
2] The lilac wire is properly fastened to the gold plated screw.
The white wire with the thick insulation could be a high voltage wire such as that used to feed neon lights. As such it would be appropriate to have the hot or ungrounded conductor connected to the gold screw.
I noticed, however, that there is no ground wire. Now this is wrong and immoral.
Also I noticed that the tab was not broken off. If the intention was to provide an antenna feed to the receptacle [just add a plug to the end of the TV's coaxial cable and plug it into the correct slots], it would be preferable for some reason to keep the UHF signal separate from the 60 Hertz power feed.
~Peter
plug- noun. 1-and object used to stop up a hole
2-a small concretion or formation that stops up a
passage, duct etc
3-small wedge or segment cut from something as a
mellon to test its ripeness
4-a cake of pressed tobacco
5-an electrical device, as with projecting prongs
to be fitted into an "OUTLET"
the other 7 definitions from webster dictionary have nothing to do with electrical devices.
I hope this helps you in calling electrical devices by their proper names. Must be the water up in New England or something.
I have a REAL hard time believing this is real and not spoof. After seeing who this came from, I don't have any question what so ever that this is for real. Oh my gosh. This has to be published somewhere. The TV never kicked on until the t-stat closed:confused::roll:
This is outrageous. OH MY,.........
I ran into something similar like that in a house except hot and neutral were done right and somebody fished in coax to add grounds later on. The guy had a TV fried and didn't know why.
