brycenesbitt
- United States
Residential style breaker AIC values have been available since at least the 50's. Back then 5kA was standard. UL raised the minimum to 10kA some time in the 60s.
Sure, but they were absolutely not printed on the breakers which is the field check issue.
And series ratings require a set of circumstances that's no so helpful in my area of mostly 1920-1970's buildings.
A fused 200-400 amp main combined with individual 10k circuit breakers is the most common setup, fed by AIC ratings of the 18k to 45k range from the power company. That holds for single family homes and apartment.
The original question was has anyone seen a breaker blow up due to the AIC issue?
Is this an identified hazard that should concern me, or an edge case?
