- San Francisco Bay Area, CA, USA
- Electrical Engineer
I have many times heard tell of (but never personally seen) “ratcheting instantaneous demand meters”. Most of the time it has been brought up by people trying to sell Soft Starters by claiming they were going to save on the demand charges. I have never seen that actually work in person, although I have seen indirect effects. In the best case of that, I put in soft starts on about 2 dozen large machines in a lumber mill, only to find out afterward that the reason they had me do that was because a salesman had told them it would cut their demand charges. I told them the truth, they were not happy, but after a couple months they told me it had worked. I took a look and their entire energy use went down. A little sleuthing and I discovered that because of having the soft starters, operators were no longer leaving machines running idle during breaks and shift changes because they had been told it was cheaper to run for an hour rather than restart, but the soft starters made them comfortable with shutting down now. That meant there were about 3 hours per day of no machines running, which reduced their overall energy use, so the demand charges were lower too because they are a percentage of the base charges. The actual peaks were the same.
Personally, I think the ratcheting instant demand charges is a myth created from people seeing an old analog demand meter and not knowing that the red needle showing the peak demand does not move instantly, that it took 15-30 minutes to register that peak.
