Coppersmith
- Tampa, FL, USA
- Electrical Contractor
I'm trying to determine if a bonding jumper is required in the main disconnect for two different solar systems. In each case the main panel already has a bonding jumper.
In system 1, the connection to the main panel is a line side tap. The main disconnect for the solar system would be in my opinion the first point of disconnect and therefore should have a bonding jumper even though the main panel already has one. Am I correct?
In system 2, the connection to the main panel is a backfed breaker. In this case, since the main panel is the first point of disconnect, no bonding jumper should be in the main disconnect for the solar system. Correct?
