electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I've got some HD wave 11.4's on a 120/240 3 phase system. The inverters are spread across All phases so some are on the high leg. The service is a closed Delta. We are getting an over voltage fault on on some, but not all of the inverters connected to the BC phases. The site is rather far away and I have not been there yet but I thought I would just throw a couple preliminary questions primarily since I'm not familiar with solar edge products (I just did the AC side connection on this system for someone).
1. My understanding is these inverters are okay with high leg systems and being connected to it. But Is there any particularly set up or setting that needs to happen for the inverters to be happy, that maybe was not set right?
2. Is anyone familiar, if it comes down to it, with increasing the high voltage set point on these? I have done it on SMA inverters, but like I said I'm not at all familiar with solar edge. Do you need any special permission from solar edge to access that setting?
