petersonra
- Northern illinois
- Semi-retired engineer
Bob the numbers can work pretty good as long as someone else is footing the majority of the bill.
I installed a 50 KW system and the payback should be pretty short if it produces what is expected.
Here it is here.
http://view2.fatspaniel.net/PECI/burkeoil/HostedAdminView.html?&eid=164519
There seems to be some issue with the reporting software as the peak numbers are very different depending on if you look at the day, week or month.![]()
A 50kw system has to be close to half a million bucks. It looks from the displays that on a good day it will generate about 250kw-hrs. Thats sounds about right for the system size.
Even at retail rates thats only about $9000 a year worth of power.
