I don't know what the batteries are for , I always though that the batteries stored the electricity till needed and went through a inverter to make ac. I am trying to find out how the system works. The little i know about pv is that they are not advanced enough to be cost effected as far as a timely pay back. I don't know what kind of dc a panel produces, what voltage or it's wattage.
Thanks again
In an off grid system the batteries do indeed store the power until required, since lights etc will be needed when the sun is not shining, also the batteries can supply peak loads in excess of the PV output.
Some systems use DC appliances worked at the battery voltage, but except on very small systems, it is useual to use in inverter to produce line voltage AC.
If a grid connection is available, then it is common not to use batteries. The PV array is connected via special inverter to the grid, any surplus power is backfed into the grid, and any demand in excess of the production is obtained from the grid.
Such systems can be justified on financial grounds, and certainly benifit the enviroment by reducing carbon dioxide emisions.
Grid tied systems do not however protect against failure of the utility supply, they turn off automaticly if the grid fails (in order to protect linemen)
The output of a PV module is typicly at from about 18 volts up to about 40 volts, wattages vary according to size, but often range from about 60 watts up to about 250 watts.
For an off grid system, modules with a nominal voltage of about 18 volts are used to charge 12 volt batteries, with higher voltages being used for higher voltage batteries.
Common battery voltages are 12 volts for small systems, with 24 or 48 volts being used on large systems.
Very large off grid systems use a battery of 96, 108, or 120 volts nominal.
For grid tied systems, a number of PV modules are wired in series to obtain the correct DC input voltage for the grid tie inverter. This is typicly several hundred volts DC.
The inverter output in generaly 120 volts for small systems, with multi voltage 208/240/277 volt inverters being used on larger systems.
