My Apologies. Writing, clearly, (might be sum kinda pun?) NOT in my Wheelhouse. Either.
YOU Will Really get Great Info/Exposure from the interconnection guide link! A Few others out there that are as good or better. No Time to look for You, Sure You can find 'em.
Brief Excerpt from the link:
"With so many service equipment configurations and local rules, interconnecting your solar PV system to the existing electrical system can be quite confusing. An improper connection can potentially spell disaster as equipment can be overloaded – don’t count on inspectors catching the mistake!"
"This post is to help clear things up so you know what is permitted by code and you can choose the best option depending on your particular situation. Unfortunately being up to code is sometimes not enough as the local jurisdiction and/or utility will have the final say so it’s up to you to make sure it’s allowed."
Jump to Relevant Section:
Much more in the link. Plenty out there. Generic search for "Solar Interconnection Guide" will return MANY results.
Art.690 is Solar Photovoltaic (PV) Systems
(again for reference; 2020 NEC Handbook) FULL Code Word 4 Word (Verbatim?)
Plus oodles of 'commentary', and be still my
Great Pictures! (
'ma native WVian, if that helps explain my appreciation for Pics)
690.10 refers You to 710.15
Part VII. Connection to Other Sources
690.59 Refers You to "Parts I & 2 of Article 705 & 712...
You wil eventually come to the realization of why SO MANY 40A 'Back-Fed' breakers are out there.
Maybe Bonus Info: *IF "Interactive" NO Back-Fed "Hold-Down Device" Required.
But Don't take my word for anything. Research it until it drives Ya crazy. Too.
On a positive note?
I musta inadvertently turned off my email alerts for replies, Can NOT even remember how/when i did that, or how i turned them back on. However, it musta worked! Your email pointing out my poor communication skills is much appreciated.
Thank You.
GREAT place to learn, YUUGE Knowledge base of very supportive & smart people. Read here for years,
but always worried i would embarrass myself asking for help/explanation/Was i reading something "correctly"?
250.24 (A) (4) springs to mind.
More free time coming up. Should be able to provide some good cover for the timid!
Good Luck!
