When we Install low voltage lighting we use a solder pot on the final connections from the cable to the fixture leads,
twist the ends together in a tight joint then dip into the solder pot then use weather proof wire nut's , works really well.
http://www.mcmelectronics.com/product/TENMA-21-3515-/21-3515
