The solder increases the contact area between the two (or more) conductors.
So how does it do this? Does it melt or somehow else distort the copper?
" Connections depending solely on solder shall not be used. "
There is a big difference between the above statement and the casual statement that the connection "must be mechanically and electrically secure before soldering."
I can loop a wire through a terminal or twist two solid conductors together to get a mechanical travel limit (such as in the Western Union splice) and some electrical continuity without having a good constant electrical connection before I apply the solder. I just cannot butt two wires together in a blob of solder though.
One test would be whether the connection (terminal or splice) could simply come apart under moderate tension if the solder were melted.
Another would be whether the wires/parts were touching each other or not before the solder was applied. A thought experiment along this line would be two wires joined mechanically by a classic ceramic insulator and not touching at all (like an insulated joint in a guy wire). Just adding a bridge of solder over the surface of the insulator would also not be acceptable.
What is a “mechanical Travel limit”
In much the same way as the conductive spring of a wirenut also does this.
Is the spring of a wirenut considered an electrical part of the circuit?
As far as I'm aware, simply twisting two wires together does not create a code compliant electrical connection.
So unless someone can show me where it says that does make a valid connection, I'm going to say as far as I'm concerned, a soldered joint is not allowed.
Is the screw on the side of a receptacle?
Non sequitur. It's not Code compliant until it's soldered. ........
Yes. Now answer my question.
You mean even using wire nuts, the joint must be soldered?
I believe that just one wrap of tape has at least a 600 volt insulation value.
I always took it as equivalent in thickness, as well as insulation value.The section of the code I quoted from uses the word equivalent. Does electrical tape alone meet that requirement? Does it have all of the equivalent characteristics of the wires insulation?
It has to be more than voltage rating.
ignore the 'do not place solder on the iron'
