LarryFine
- Henrico County, VA
- Electrical Contractor
The other real tip (like there are only two) is to get the work itself hot enough to activate the flux and flow the solder, and not just blob it on the surface with the iron or gun.
Or you're holding the work with one hand, the soldering iron or gun in the other hand, and the solder in your mouth, trying to not breathe in the smoke and fumes from the flux as the solder melts.You haven't really soldered until you've done it in contorted positions, holding it in place and soldering at the same time, then have a ball of hot solder fall on your hand and you don't move so the joint doesn't get messed up while it cools![]()
