Hello all,
First time poster here....
I have an application where I am designing a gas flow control cabinet. Basically, there are two compartments in the cabinet; one side contains all the gas controls, the other contains all the electrical. The gas compartment, housing plumbing for Hydrogen, Propylene, Oxygen, and Nitrogen, will have very little electrical in it... only one location-rated pressure switch and a number of solenoid valves. The whole cabinet is consider to be in a C1D2 location, and the gas section is also considered C1D2. The solenoid valves that I'm thinking of using are ASCO valves, rated C1D2 Group A,B,C,&D. The electrical side compartment is purged and pressurized.
I know the pressure switch will require potted seal-off fittings, and I know where I have to locate them. I have to run the solenoid coil's wiring back to the electrical compartment. I plan on using flexible sealtite. Will I need a seal-off fitting on either side of the the sealtite?
Thanks in advance,
Rick
Thanks in advance,
Rick
