What level of power is running through all the zip-tied wires? Is the insulation/jacket designed for exposure? Are we looking at workmanship, or imminent failures?
I got state certified to do PV (easy test), but never actually did any, and have zero experience in that aspect of the trade. I know nothing about how it's actually done.
Those disconnect switches are not rated to be in those positions, it's usually no more than 15 degrees off vertical. They are going to fill with water...
Are those the type of solar panels with the "Enphase" inverters on the back of each one, so that those are all small AC circuits? Usually if they are DC from the solar panels, the wires are all going to a "combiner box" of some sort, then to the inverter. These all look like they are going into the Disconnect switch and there is one larger cable going out. That then begs the question as to whether or not that disconnect has listed lug assemblies for all of those small wires, or if they just jammed a the bunch of them into one large lug. Given the hackish nature of the entire job, I'm betting it's all bad.
Are all those panels being held down by cinder blocks?
someone is going to be paying a lot of money. Typically the roof should only be a couple of years old when you install a system and most of the time it is a membrane roof. This was more of just an asphalt roof with some type of spray on layer over it that was pretty old to start.So what happens to this place when it needs a new roof? Can all of that be unplugged and moved?
In my own mind that is exactly the reason it has been done this way... either the owner said no permanent installs or knows they need a major roof repair and so wanted a temporary install. Because that is what I see, a temporary install.So what happens to this place when it needs a new roof? Can all of that be unplugged and moved?
Won't keep them in place with the wind gusts we often see during thunderstorms around here.Are all those panels being held down by cinder blocks?
Spray on roof finish, can seal those supports right into the roof, and add some additional securing at same timeSo what happens to this place when it needs a new roof? Can all of that be unplugged and moved?
I'm sure whoever designed that roof was thinking of PV units at that time as well, let alone all the cinder blocks to weight them down.the picture of the big rigid shows at least 40ft, double check the rum doesnt need expansion joints. and why rigid.. old roofs do not like more weight than needed
