Re: Sound Board to Light Controls
Hurk27To answer your questions
1. What I did was from the end of the building where the circuits are I ran 3 each 3/4" emt feeds to 2 large 10 x 10 boxes. All power circuits run to 1 box then down thru pvc to my gutter switching area then into the 6 gang boxes via terminal strips to allow changeing around. Then the switched circuit returns back to a area where it picks up its neutral and terminates in a 1900 box. From there I tap in with 12/2 romex to the first light and then on to the next and so forth each run of emt has a seperate #12 thhn green in color its full length includeing all 1900 boxes there is bonding everywhere that I pre-put in to prevent feed back.
2. The neutrals run thru a seperate 3/4" piece of emt and the 1900 boxes they are in are right alongside the feed emts and the return legs . all circuits are numbered so they done get out of correct circuits.
All sound circuits are on seperate circuits used only for the sound board, the computer tie ins, the vcrs the cd players and the amplifiers. All wiring is done to 1999 code as that is what the local people use there call not mine.
This is a Article 550 type builing with 4 each 150 amp services run off a common underground feed from the main church 500 yards away with no problems existed for the past 10 years.It is a factory manufactured building.It is about 40 foot square with the speakers at the power end of the Church and the sound booth is at the other end of the church. As far as other contractors they dont want to be bothered but my partner is a contractor as well as I am for a very long time and we bonded everything in site as well as grounded everything in sight when we started out we removed over 400 feet of extension cords and now the building is up to code every where. Its just this sound thing is driveing us nuts.
The remark about God is right now I am fed up up to my ears with the dooms day crowd in our country. Nobody wants to do nothing for anybody else unless its there way or with enngineered drawings.
I think removeing the dimmers will probably fix the problem cause the system I built was working okay and I tried to get too fancy putting dimmers on lighting circuits..
Wayne understand nothing against anyone but when you donate time, material, energy and the churcj people speak nothing but nice its great. Then you ask for a little advice and the code book warriors come out with off the wall stuff it gets very very frustrateing.
Thanks for your input it is appreciated
