South Carolina LLC versus Journeyman / Master Electrician License what is the significance of having one versus the other.
Tommy1776
SC
Industrial Electrical Maintenance, AAS, CW
South Carolina State Board of Registration of Professional Engineers
LLR
SC Department of Labor, Licensing and Regulation
SC Residential Builders Commission
https://www.llr.sc.gov/res/PDF/Residential_Specialty_Electrical_App.pdf
MASC Municipal Association of South Carolina
https://www-test.masc.sc/programs/trades-certification
Electrical based on NEC 2014
Trades Certification Brochure
https://www-test.masc.sc/SiteCollectionDocuments/tradesbrochure.pdf
Application
https://www-test.masc.sc/SiteCollectionDocuments/tradesbrochure_application.pdf
PROV, Inc. Exam Scheduling
Provexam.com
Journeyman Electrician
A Journeyman Electrician is qualified and tested to perform work in the electrical trades while employed by a Master Electrician.
Number of Questions 70
Time allowed (hours) 3
Subject Area # Quest.
Communication Systems 4
Equipment for General Use 6
General Electrical Theory & Principles 9
Motors & Controls 3
Plan Reading 4
Special Conditions 3
Special Equipment 3
Special Occupancies 2
Wiring & Protection 14
Wiring Methods & Materials 22
Tommy
An LLC is a type of business structure. A journeyman or masters is a trade license. Depending on state laws, one may need to have some sort of business structure (such as an LLC but there are other options) to be in business as an electrician.
In VA, an LLC and Journeyman/Master are two distinct things.
Only a legal business entity can become a contractor, and must employ a Master in the specialty trade.
Greetings Mr. Hv&Lv
I have the time in grade as an electrician {40 years Nuclear I&C III Technician} although after taking the Journeyman / Master Electrician Exam Prep class, I have learned that in order to qualify for the MASC Municipal Association of South Carolina test which is through the Provexam.com, that I must have worked under a master electrician for 2 years and have them send a written letter so that I can qualify to take the test to become a Journeyman / Master Electrician for the state of South Carolina.
Also, I have a 2-year Associate Degree that would qualify me for 1 year of experience as an electrician.
There are other specifications to be considered in order to take the Master Electrician test.
Tri-County Technical College
https://cce.tctc.edu/wconnect/CourseStatus.awp?&course=202XEEM54502
If I wanted to become a qualified Electrician to perform work on my own I would consider taking the LLR and it is based on my assets to qualify.
https://llr.sc.gov/
Tommy
