brantmacga
Señor Member
- Georgia
- Former Child
Okay I need a starting point here.
I got a call about a spa installation I did about 3 months ago; after a hard rain, the homeowner finds the GFCI breaker has tripped.
It is a C-H BR type, 2-pole GFCI (came in that spa package). The original breaker that came with this had a defect, and I replaced it.
Its mounted in a 2-sp disconnect. #6 THWN goes through 1" PVC about 80' to the spa.
The spa is custom-built, and the pump and heater are in a self-contained housing that sits just a few feet away (plumbing leaves this unit and goes to the spa).
There is a hard-wired LV controller that is mounted in the brick that surrounds this spa.
The #6 goes into a junction box w/ terminals mounted on a circuit board. The pump and heater are plugged in on the underside of this housing.
That's about all I can remember from the install.
I've got to go by there and look at it within the next few days. If you've got any pointers on what to look for, I'd appreciate it.
