395Garrison
- Temecula
- General Contractor/Superintendent
I purchased a spa and I am planning on pulling the conductors over the weekend. The spa requires a 50 amp 240v four wire set up. From the house panel to the GFCI disconnect the run is 175’, from the disconnect to the spa is another 35’. Looking at conduit calculations with a long pull of 4 awg in mind, I installed 1 1/4” schedule 40 underground for the long run and 1” for the shorter run. My question is, after the disconnect am I able to step down to 6 awg or should I run 4 awg all the way to the spa connection? Haven’t laid my eyes on the spa connection yet, but imagining 4 awg might be a pretty tight fit. On top of the 4 awg, the spa’s wiring diagram designates the use of an equal sized ground wire as the conductors.
Thanks,
Garrison
Thanks,
Garrison
