Brownetown
- Va
- Electrican
Can you use UF wire for an outdoor above ground hot tub. I see that for wiring methods it says that it is okay but for feeder wire. It has to be in conduit. If I stay 5’ away and run UF cable to my spa disconnect would that be acceptable? 50 amp thinking using 6/3 UF to disconnect then a ground as well to S.p.A. disconnect
