Good morning. I think NEC is silent regarding clearance requirements from bus to the enclosure. The same standard would apply to bolted connections. In other words, a compression lug is terminated to the gear. Bolt is facing outward. Is there a required distance from the bolt to the cover? Thank you for the help.
