Spacing for EMF protection on underground low voltage wiring near 110v
GregSt
New member
I want to put a 110V (12/2) wire in a 1/2 conduit, as close as possible to another half inch conduit with low voltage security wire (to run a heat sensor and a motion sensor in a garage). The length of the run is 150 ft. I have to dig the trench by hand due to its location.
When neither wire is shielded I'm told by different local sources that the two conduits (which are 100% PVC) should be either 12" or 18" apart.
I've found a shielded Ethernet 4 pair cable suitable for direct burial. It's shielded with aluminum foil, though in my case it will be underground in its own 1/2 PVC conduit. My question is, if I ground to the foil both of the ends of the shielded Ethernet cable, how close can its conduit be to the other conduit carrying 110v? I'm hoping the answer is 4" as there would a lot less digging!
Thank you,
GregSt
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
