mopowr steve
- NW Ohio
- Electrical contractor
So I go check out a small remodel job and the customers have some lighting fixtures setting there to be installed, right away I notice some small porcelain terminal block with what almost look to be speaker wire running to the sockets, it lacks mounting bracket and grounding wire and even the sockets look a little different.
So I look for a listing, it has a CE listing but it's for 220 volts.
Then I see where it's from ......Spain
Now correct me if I'm wrong but there is no way I can install these in the US right? Unless Spain offers a conversion kit with bracket, EGC, 120v label, etc?
Ok so now you U.K. Guys, a couple questions.
1- do you use junction boxes to attach your lighting fixtures to?
2- do you run an earthing wire or equipment ground wire to your fixtures?
3- when doing 3-way switching are you only switching 1 of the hot leads?
