ill be sure to fax you a check asap
Make sure there's lots of zeros on it.
anyone ever use one of those holesaws that are used to cut through the soffit and the roof in one shot....it's about 2 feet long and its got an extra deep holesaw...the bottom is a guide and is stationary....know where i can get one?....ive searched it but can't find it
Took a 20" peice of 2? IMC, and matched a hole saw to the OD. Welded the hole saw to it, with a hole on the side to access the pilot bit set screw. Weled a flat plate on the other end with a peice of 1/2" hex key.
Makes doin' risers a whole lot faster!
Which came first, the LB or the downspout? :grin:
ooh. i want one. ooh.
That shaft portion looks a LOT like conveyor roller stock.
Don't re-invent the wheel (shaft) if you don't have to.
Thanxs once again 480. I'ld hate to insult you with a large check but please know I'll be thinking realy nice thoughts about you every time I use this tool!!
hm. looked at it.... ok.. this isn't that hard to do...
get a holesaw arbor, chuck it in a 2' extension.
get a new holesaw, and a 22" piece of imc
weld holesaw to imc, grind smooth... (duh)
spin holesaw onto arbor and extension... drill hole...
smile....
ok, i can do this. good idea... thanks...
We just use a 1/2" X 24" bit to go through both the soffit and roof. Then we switch to the appropriate sized hole saw. We take the 1/4" pilot bit out of the hole saw and use a long reduced shank 1/2" bit instead. Now you can drill out the 1/2" hole up from the bottom of the soffit and then down through the roof. The long pilot bit allows you to hold the hole saw plumb when drilling down through the sloped roof.
