- Massachusetts
LarryFine said:Now, compare even half of those 8 hours to a single crew getting 30 minutes less work done each day.
I am not following you.
iwire said:I am not following you.
I meant compare the time going back for troubleshooting 'fast' work takes to the time that extra half hour takes if it means no callbacks.iwire said:I am not following you.
PCN said:I used to work for this guy in San Diego in the early 90's, his main gig was installing ceiling fans. The two of us could install one in 30 minutes tops w/ switch. He would be sceaming at me the whole time I was in the attic to find a source of power!, nail on the 2x4 for support! etc.....If I needed anything in the van he'd scream "you betta run you little #%*^# !!!!" Man I hated that guy. It was demoralizing. What a hack, I quit after two weeks and went to work for real contractor.
My point is- quality first, it's not worth rushing if you make mistakes. Mistakes = $. Be proud to put your name it.
And now, it takes you two hours like it's supposed to.PCN said:I used to work for this guy ... installing ceiling fans. The two of us could install one in 30 minutes tops w/ switch.
PCN said:. The two of us could install one in 30 minutes tops w/ switch.
I was wondering the same, figured they gave it a quick hard spin by hand and collected the check and out the door.peter d said:Yeah, but did it actually work?![]()
stickboy1375 said:I was wondering the same, figured they gave it a quick hard spin by hand and collected the check and out the door.![]()
electricalperson said:is being fast part of being a good electrician? i dont really know if im fast or average. i tend to take pride in my work and try to do a good job at what i do. if i try to go fast things start to get missed or screwed up. i dont drag my feet around all day i try to do the best i can and work as hard as i can without killing myself
Fulthrotl said:"I WANT YOU TO PULL THAT WIRE, AND I DON'T WANT IT TO STOP
MOVING UNTIL IT'S ALL THE WAY IN. IT STOPS MOVING, AND YOU ARE
FIRED!!!!"
ok. so he gets to the wire cart, and screams "GO!!!" and i take a turn
around the handrail of the scissor lift with the string, and drive off....
he did pretty good at first, but the lift had a high speed that kicked in
after 3 seconds....![]()
the spools started coming off the cart, and spinning around his feet,
and bless his heart, he kept feeding, and never said a word.... just
dancing there with half a dozen spools twirling.....
i drove all the way across the building, out the door, down the ramp,
and over to my van on the far side of the parking lot... about
1000', pulling all the wire with me. lowering the lift as i went,
threw my tools in the van, and drove off.
it was a short day.
randy
Now, that's quite poetic! :smile:Fulthrotl said:if you watch a craftsman whose work is excellent, you will find that he is
following no one set path to accomplishing a goal. the work at hand
determines his thoughts, and his thoughts determine the work at hand,
until he is at peace at the same instant the work is complete.
that was pretty funny. i bet that guy was pretty madFulthrotl said:my first superintendent told me "son, we don't get paid for pretty, we get
paid for done". that's how he looked at it.
what i've learned is that if you learn your craft well, speed will take care of
itself. work is a balance between boredom and exhaustion. some days i fly,
some days i can do the world a favor by staying in the backyard and
swimming in the pool. as you work with different people from different areas
of the country, you will find that they apply a different ethos to what they
are doing, and to their means and methods.
i absolutely cannot stand doing stuff hard and stupid. the whole thing for
me is doing something with as elegant a solution as i can devise. and making
a fair piece of change in the process.
i have a little picture on the wall in my house, and it's one of the main
reasons i am self employed... it looks like this:
if you find someone who actually cares about what they are doing, they
are usually attentive and occupied, and work quality and output are not
even a question.
i had a journeyman when i was an apprentice, and this jw had a habit of
eating black beauties, and running on them for 3 or 4 days at a time.
(it was the 1970's, what can i say?)
we were pulling out a tilt up, the lighting home runs, and i had conduits
going thru the pour strip, and up the wall to the glue lam, and across the
glue lam, thru 5sd boxes, and was using a pull string, and this jw stood
on the floor and screamed at me (i was 20' up on a scissor lift)
FIRED!!!!"
it was a short day.
randy
