Re: Speed wire Receptacles
My objection to using 12 gauge wire on a 14 gauge circuit only has to do with the situations I described, not with a long run or other special case. I also did not say it was against code.
I can see some homeowner in the future seeing 12 gauge wire and incorrectly thinking they can put add a 20 amp outlet on a circuit, never bothering to check the breaker even when they turn it off to add the new outlet.
If there is a bona fide need or good reason for a larger wire size then use it. If however there is no good reason for it then I say stick with the wire size already used on the circuit.
