splices in main panel?
I was always told that you can not splice or wire nut within a breaker panel? Also that you can not use the main breaker panel as a pull can, to pull circuits through it? Can someone please provide NEC code if there is one.
Thanks
That's an old myth that just hangs on. See article 312.8 and read the whole section.
Roger
The electricians and Home inspectors tale.
Oh no you have a splice in that panel. Ya need to fix that.
OK dude.....
And I just go about my day.
Hey I don't like splices in panels but what would be better in a remodel a Jbox above the panel because the wire is too short to make it to the breaker or splice and wire nut. ,,,,
The things we worry about.
