Splicing belden signal cable
marcosgue
Tampa
Is illegal to splice belden cables inside the junction box? What's the code violating?
The nec do not refer that splicing those cables isn't allow. Thanks
Need more info. Belden is a brand, they make all kinds of cable. What voltage(s) involved? What else, if anything, is in the box?
There is no code rule that says you can't splice these cables. The code does not care if the splices work...only cares about the system being safe from a fire and shock perspective.
Application requirements might be what would have objections to splicing a shielded cable, presuming you are asking about a shielded cable.
Will it work, likely yes. will it allow signal interference that wouldn't be there if unspliced, possibly.
kind of comes down to what kind of signal interference can be tolerated by the specific application.
Some applications if you happened to damage the cable and wish to splice it back together, at very least may need to recalibrate for any changes in the cable for the most accurate results. This can be critical with items that need high precision with the signal being sent. Even trimming off excess cable length might require recalibration in some applications.
