solarengr
- Chicago, IL
Is there a limit to how many splices or taps can be made on one GEC?
Here's what I'm trying to do:
I design solar systems using micro-inverters (every solar panel has its own inverter). A big pain (and high cost) part of this is that each inverter needs to be grounded. This ground not only serves as an equipment ground (EGC) but also as a grounding electrode conductor (GEC) since one of the DC leads from the solar panel is bonded to the metal enclosure of the inverter. What I'd like to do is pre-install a bare copper #6 GEC to the microinverter so that when my subcontractors are on-site, all they need to do is use either a barrel-shaped splice or C-Tap with a compression tool (from Panduit, Thomas and Betts, or whoever) and splice the GEC from two adjacent micro-inverters.
There are 21-24 micro-inverters per circuit so there would be 21-24 splices/connectors per circuit.
Is this code-compliant? Does anyone see a problem with this?
From my understanding of 250.64(C)(1), this is acceptable as no limit is set.
Thanks in advance for any suggestions.
