Splicing oversized wires due to voltage drop
arnettda
I am running 4/0 direct buried cable for a 100 amp feed due to distance. I have not oversized a wire so much that it will not fit the breaker. Do I install a jbox below each panel and make splices to wire that will fit under the breaker?
Thanks
There seems to be a other opinions though?
ptonsparky made a good point. It all depends on where the first 100A breaker is, i.e. you can put 4/0AL on a 200A breaker and run it ten feet on up to ten miles or more and not have to use a larger EGC. Put the same wire under a 100A breaker or less and you need to upsize the EGC.
Make sense? Of course not.
What's important is- Why did you upsize to 4/0? What is the connected load? If you need 100A at a great distance from the source then voltage drop is a real concern and the EGC should be upsized.
It is only with 15, 20 & 30 amp circuits that 250.122(B) causes real heartache.
Once you get above those sizes things make much more sense.
60 amp load 560 feet away.
It gets better but doesn't go away. Take a 40 amp circuit and increase conductors and you are supposed to increase EGC by same proportion, yet if same ungrounded conductors were part of a 60 amp circuit the EGC could easily be smaller than what may required by the 40 amp circuit.
Bringing a 4/0 conductor into a space intended for 60 or 100 amp conductors may have wire bending space issues and the reduction may still need be done in a separate enclosure.
Did I say it went away?
Do you think I am unaware of the rules?
It just seems every time you quote me it is to correct me over things I did not say
Arnettda:
Making assumptions.
A 60 amp load would use #4 al. A 100 amp CB would require a #6 al for an EG. Increasing the size of your phase conductors to 4/0 al would require a proportinal increase in size for the EG resulting in a 2/0 Al. 4/0-4/0-2/0 is a typical cable configuration that we bury.
4/0 AL could be protectecd by a 200 Amp CB and only require a #4 AL EG. Table 250.122
4/0 AL SE conductors, #2 Al. Table 250.66
Did it ever occur to you that maybe I was just adding my own $.02 and was talking to the entire forum and not just you?
Sorry for peeing in your Cheerios.
