harborrick
- Irvine California
What are we using to properly splice THWN to 1k PV Cable in J Boxes? Or what is proper way ?
Thank You in advance
And current/conductor size? Why not regular wire-nuts?What's the actual system voltage?
If you don't need the 1kV wire, why use it at all? If you need it on the roof because of DC voltage, you need it all the way to the inverter. Either way, I don't see the reason for the splice. That said, a splice between them is no different from any other splice.What are we using to properly splice THWN to 1k PV Cable in J Boxes? Or what is proper way ?
'Regular' wire nuts aren't rated for more than 600V.And current/conductor size? Why not regular wire-nuts?
His thread title and his question are contradictory about voltage. If his DC voltage requires 1000V wire he should not be splicing it to THWN at all. If it doesn't, then wire nuts should be OK.'Regular' wire nuts aren't rated for more than 600V.
Buchanan splices are a common preference in the solar industry. They seem to be more reliable in NEMA3R boxes on the roof.
600 DC MaxWhat's the actual system voltage?
#10 and #8 PV cable at 600v DCAnd current/conductor size? Why not regular wire-nuts?
Pending on sun. Usually 400 to 500 volts .What's the actual system voltage?
I am being told that DC conductors should be a straight thru splice. That if I use a small Polaris ,it would heat up.'Regular' wire nuts aren't rated for more than 600V.
I don't know why that would be; did whoever told you that tell you why?I am being told that DC conductors should be a straight thru splice. That if I use a small Polaris ,it would heat up.
he told us DC runs in one direction and that a Polaris rated for voltage would overheat. I have seen one of our Polaris heat up and that could of been with a bad termination.I don't know why that would be; did whoever told you that tell you why?
THWN is only rated 600v, If you can use that wire, you can use a 600v rated terminationTHWN
Yeah stuff happens. It is usually due to installation error, manufacturer defect, or too much ambient heat. In my experience.I have seen one of our Polaris heat up and that could of been with a bad termination.
I'm gonna be blunt: That's nonsense.
I would use Buchanan splices caps with insultors. It's how I was trained and they're the one thing I've yet to see fail.
Those wirenuts are comfortable to work with also I like them for regular uses alsoWe switched over to using the 1000v rated yellow and red wire nuts from Ideal. They’re expensive but they work great.
Clearly in this case a regular wire but would be fine, but the 1000v versions do make a nicer connection.
Do you use the four way crimp Buchanan tool? I lost mine.
Both big boxes have them stocked and platt was promoting them idk if they still are. Next best for comfort I think are the 3m red yellow with the boot on the end kind of the same type of product but less wingsI would if I could find them! I found a box and then wasn’t able to get any more stock at our distributor
Yes that's the only legit way to use them....
