440 single or split
440 single or split
Alwired,
Compliance to 440 per manufacturer instructions on a split system is the norm on a residential configuration. The internal unit has it's own disconnect breakers for the heatstrips/exchanger/handler section within the unit and a separate disconnect must be supplied for the outside compressor. Last install I did was 2001. rbj
440 single or split
AlWired said:With regard to a split system A/C system (heat pump outside and air handling unit inside), would it be a fair assumption to say the heat pump complies to Article 440 while the air handling unit complies to Article 430?
Thanks in advance.
Alwired,
