blueheels2
- Raleigh, NC
- Electrical contractor
Have you seen the small room AC units? The condensing unit is outside and it is fed by a disconnect. It has a control wire that goes from this unit to the inside unit. This control wire carries 120 volts to power up the unit inside. Has anyone seen a unit like this. The inspector says you need a disconnect inside as well. If the outside disconnect is lockable do you need the disconnect inside.
