Bluegrass Boy
- Texas
- Commercial/ Industrial/ Maintenance Electrician
You mentioned block wall, make sure to drill into the brace section of the block, or if you had to hit the hollow spot, then we used the hollow wall anchors. I have seen toggle bolts used, but would not recommend 1/4 in. The toggle wings are not very strong and you would have to upsize.
Here’s an example of hollow wall anchors we used often, with an anchor setting tool.
