SQ D MAL36400 needed
acrwc10
Master Code Professional
CA
Building inspector
I need a sq d MAL 36400 moled case circuit breaker for a service job. if any one happens to have one they would like to part with send me a PM. Thanks
Check the used circuit breaker market on line, if you can't locate one IM me I can put you in contact with a used dealer that can locate most anything.
The internet is a great way to find things. I thought I would check to see if any one here may have pulled one out of a new switch gear or had one for what ever reason. It doesn't need to be in the box just "like new" would be acceptable. I will have it tested before installing it. The one it is to replace is locked in the on position, from what I am told. It is a load that I can not shut down to test unless I have a back up part ready if it fails to close and restart.This is the main in a 120/208 3/0 switch gear that is buss in and bolted not cabled. Is it possible to change to a different stile of breaker like a SQ D-LAL type?
If this is a critical lopd that can not be shut down, why in Earth is the customer quibbling over a few pennies (in regards to revenue they might lose with a shut down).
Sell them a new CB
Well, I always wondered what a $5000 circuit breaker looked like!
Sell them a new CB
I was having trouble with this as well.
Sell them one to install and another to sit on the shelf. We have a customer that has spare sections of 2000 amp bus duct 'just in case'.
George, don't believe the list prices. ;)
My Square D catalog lists $6300 for a new one (with 3 poles).
I always knew you couldn't believe the list prices, but it would be nice to know what kind of multiplier to use to use to get more realistic prices.
I use RS Means for all my project estimating. Even it lists $3425 as the material price for a 400A MAL. If they really only cost $2000, then I am supprised. I expected RS Means to be a lot closer. If the electrician's bids come in in-line with my estimates, that gives them about a 90% mark-up on material. What gives with that?
Steve
Steve
Well it is the reason more customers that have multiple locations built each year are supplying the lighting fixtures and distribution equipment.
well, my local sq d supply house is around $2600 for the breaker. But, part of the fun of owning a company is knowing where to look for things. So, my main molded case breaker supplier is $1700 for a new CB. Full warranty, guarantee, etc. We've used them many times in the past with no issues.
But without knowing where to look, it's an extra $900.
If you finding yourself needing these high dollar breakers very often, sign up for a free subscription to "The Electrical Advertiser" monthly magazine. There must be a few dozen used and NOS breaker dealers in that magazine every month.
