Installed 2 22.5kva mpz 480v primary the unit was powered up and left with no load for a month. When we returned the xfmr was very hot! Could only touch it for like 2 seconds. I put a clamp on the 480v coming in and there was a 5 to 7 amp load on the 3 phases.
Again there is no load on the secondary. Everything is grounded/bonded properly
the incoming voltage is a little high around 283v ph to gr and 495 ph to ph. Any thoughts
