majorminotaur
- Buffalo, NY, USA
- Electrical Engineer
Hello all. We've got a whole bunch of Square D Model 6 MCC's that were installed in 1998 with pilot light devices that basically have a flawed design. The trim that holds the lens in snaps into place. Well, 20 years later and the plastic is fragile and when you pull off the trim to replace the lamp, the plastic tabs break off. I'm being told that they don't make this plastic piece anymore and are trying to sell me a replacement for the whole assembly for $50+ a pop each parts plus not an insignificant amount of labor to change them all out. The plastic piece itself can't be particularly hard to manufacture, so here I am thinking there has to be an easy solution to this and I can't be the only one facing this issue. Does anyone have any experience with this problem? If so what was the solution? Does anyone stock these parts still? Get a plastic manufacturer to create new ones custom? Knuckle under and pay thousands of dollars to replace? Thanks in advance.
