Measure the nominal voltage Line-Neutral.
120V is good to go.
208V means you are on the wild/high leg.
Straight 2-wire 240V loads can be connected to the wild leg
A circuit breaker w/ a 120/240V slash rating cannot be used on the high leg a 240V 2-pole must be used, cost & availability could be a issue.
