sparkyrick
- Appleton, Wi
Some guys just lick their finger before touching to test for voltage![]()
Yeah, I've seen that from a rookie years ago. I hope he's still alive.
I have never seen that tester, but my troubleshooting choice for line voltage systems will continue to be a solenoid tester. I have zero need to see the digital voltage display for troubleshooting line voltage systems and really like that I can just hold the solenoid tester in my hand and know what is going on without looking at anything.Indeed it does, but I prefer the Fluke T+ Pro as it has features the Ideal does not (continuity beep, flashlight, digital voltage display), and is vastly superior to a solenoidal tester in my opinion. It's also low Z.
I should loan you one of my Fluke 12s. It can be set to AC or DC or be set to auto sense as well as doing everything your Milwaukee does.Edit to add: the only chink I found in its armor is that auto-switching to DC is sometimes problematic depending on the circuit. I have had to go back out to the van one time and grab a meter that manually changed from AC to DC to figure out a circuit. One time.
Compact, rugged enough for everyday use with the case, simple to use. It's so good they don't make it anymore. Now everything thing they make includes a dial, twenty five buttons, and a cappuccino finding app.Fluke 12? The pocket DMM thing I'm finding on Google...?
Just like everything else....the kids always want the fancy new toysMust be a generation thing. The elders like the wiggy. The youngings like the DMM.:lol::lol:
For my money: Milwaukee 2205-20.
Low impedance meter, continuity down to fire alarm resistors and below, audible continuity, rugged enough to wear on my bags. I loaned it to one of my guys, and somehow he knocked out the backlight and LED flashlight on it, the meter still worked. I had bought some ill-fitting leads for it a long time back and finally decided to start over, bought a second one a couple weeks ago and gave the first one to one of my students.
Just like everything else....the kids always want the fancy new toys![]()
Kind of like the T5 but with some improvements?
Exactly. The T5 is a good tool, but if you're doing any work on fire alarm it is blind, and it doesn't have a low impedance setting for basic troubleshooting.
If it is not broke, don't try to fix it.That's definitely an "old school" mentality.
And I just see ZERO use for a meter to trouble shoot 120 volt control circuits. It does not give me any additional information that I need.Not necessarily, I just find modern testers to be a vast improvement over solenoidal ones. I'd much rather have fuel injection than a carburetor. They both get the job done but fuel injection gets the job done a whole lot better.
And the one I have is CAT III, and yes that does place limits on where it can be used.I agree with much of that, they are great tools.
Yet still in many facilities and companies you won't be using one that is not cat rated.
