Tulsa Electrician
- Tulsa
- Electrician
What is the utility doing for metering? Just curious
			I understand, that’s what I’m saying the underground water pipe is plastic…. That’s why I only need ground rods. The separate structure may have a metal water pipe, but I believe they’re abandoning water into the structure making it no longer a gec….Doesn't matter what they ran inside the building (although you're supposed to bond if metal). If the underground water pipe to the building is metal it's considered an electrode and you're supposed to use it.
Owned by the same company they just ct it.What is the utility doing for metering? Just curious
Thanks, I work alone. I know I’m not the best. I do try to take pride in my work, and I try to be compliant with my installs. This box is 36”x36” and was a pain to hang alone!I missed that. Sorry I thought it was a temp set up. I zoomed in closer.
Thanks
Nice looking work
