jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Ok, I pigtail and back stab.
Engineers with larger degrees than I, say it's ok.
The UL guys and gals say it is ok.
The NEC folks say it is OK.
Q: can you use #14 gauge wire, off of a 20 amp circuit with #12 wire pig tailed, and back stab into a 15 amp receptacle or switch ?
hmmmmm ...:?
I have done service work since 1976 and have lost count of how many times backstabbing was the culprit. If you mostly do new work, you will never see the problems because someone else fixes them. I have seen the simple issue of wire pulling out the back and the more serious issue of receptacles smoking & melting from stabbing.
Engineers probably designed Federal Pacific and Zinsco Equipment. They are not infallible.
I have seen a lot of junk with UL labels, such as Federal and Zinsco above. I have seen their labels on equipment wired with hots to shells of lights, ground lugs secured with tek screws to thin metal, wiring boxes so tight I could barely get feeders in, etc. A lot of good equipment carries UL labels but it tends to be a money racket in my opinion. The cost to even get it reviewed by UL is out of sight for many smaller companies.
I lost a lot of respect for NEC over this very issue; allowing stabs while requiring AFCI.
